Install Haveged... [ERROR]
kelesida
Сообщение kelesida » Ср апр 09, 2025 7:40 am
2025-04-09 04:38:11 (4.83 MB/s) - ‘install.sh’ saved [34728/34728]
Please Wait...
Virtualization test: PASS
******* THE INSTALLER BRAINYCP CORE v3.02 *******
Detected OS Version: CentOS 9
Detected Server Name: cloud-starter-intel-nl-2-v-2-5669864-439347.novalocal
Detected Server IP: 185.93.6.193 2a13:4ac0:10:0:f816:3eff:fed8:395e
Detected Server RAM memory: 2327220 KB
Detected Server SWAP memory: 2097148 KB
Checking RAM size... PASS
Checking SWAP size... PASS
Checking type IP address... FAIL
The following issues were found:
*) Your IP address is of a dynamic type (DHCP), but you need a static one.
A dynamic address of a network interface can lead to incorrect operation of some services,
for example, issuing certificates. And also, disrupting the installation process itself.
Please also note that technical support cannot help you until you fix these problems.
Continue installation? {y/n}: y
Continue and ignore these errors.
System update checking, please wait...
##########################(100%) [DONE]
Type Script: KVM
Install tools network... [OK]
======= Install BRAINY ISP panel ========
======= Setup " apache2.4,nginx,php54w,php56w,php71w,bindserver,imagemagick,logrotate,MySql5.5,phpMyAdmin-4.9.4,exim,spamassassin,clamav,proftpd,csf" ========
Configure process download... [OK]
Download version... [OK]
******* BRAINYCP PANEL VERSION 1.09 ********
Install BrainyCP version 1.09
Wed Apr 9 04:46:09 EDT 2025
Disable SELINUX... [OK]
Prepare install... [OK]
Configure repo... [OK]
Version os: centos 9
Architecture os: x86_64
Configure limits... [OK]
Update THP Memory... [OK]
Configure network... [OK]
Run install script.
Install SSL... [OK]
Run process Haveged
chmod: cannot access '/usr/local/brainycp/ssh/*.php': No such file or directory
chmod: cannot access '/usr/local/brainycp/ssh/*.sh': No such file or directory
[root@cloud-starter-intel-nl-2-v-2-5669864-439347 etc]#
[root@cloud-starter-intel-nl-2-v-2-5669864-439347 etc]# mc
Как можно починить данную ошибку Install Haveged... [ERROR] ?
Re: Install Haveged... [ERROR]
Сообщение alenka » Ср апр 09, 2025 2:43 pm
Покажите вывод по команде:
    yum -y install haveged
